Model A1312 / Mid 2010 / 3.2 GHz Core i3 or 2.8 & 3.6 GHz Core i5 or 2.93 GHz Core i7, ID iMac11,3
383 Questions View all
Utilising an extra eSATA port on my mid2010 iMac
Adding an eSATA port in a mid2010 iMac was announced just a little after the iMac came out and here is an article regarding this at the time… https://www.macworld.com/article/1151094...
Problem is that i cannot find any relative how to video, nor some other info on how to do this right… i wish iFixit could do this :-)
Add a comment
1 Answer
Most Helpful Answer
There really is no secret here! The 2010 27” model has three SATA ports.
Back side of the 2010 27” logic board
All OWC did is design a custom mini-SATA (logic board side) to eSATA cable which is mounted into the port in the logic board and the RAM access door. Don’t forget this system only has a SATA II (3.0 Gb/s) interface so you can encounter issues with SATA III (6.0 Gb/s) drives (fixed). If the drives spec sheet doesn’t list SATA II (3.0 Gb/s) compatibility don’t use it!
eSATA really didn’t get any traction as OS-X (or even Windows) can’t handle loosing access to a drive before properly dismounting. and even eSATA is not without issues with static discharge!
Score 2
2 Comments:
Why did OWC made a custom miniSATA to eSATA cable? Isnt it possible to find such a cable on the market?
by
It gets into options! OWC thought people would buy theirs over others.
Remember we are past using SATA with Thunderbolt3 & USB-C. Demand for it is not really there any more..
by
Add a comment
Add your answer
genik will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 152
