Witch differential oil to use
Anyone know the exact differential oil for 2000 Dodge dakota 2wd? Not sure to use 75w90 or 80w90.
It should tell you in the owners manual but there isn't a big difference you can use 75/90 80/90 it doesn't really matter. You can use standard or synthetic. The only thing you do need is the additive if you have a limited slip differential. If only 1 tire spins in the snow then you don't have a limited slip differential.
Past 24 Hours: 0
Past 7 Days: 17
Past 30 Days: 65
All Time: 1,879
