Samsung's wireless earbuds. Released in March of 2019 with the Samsung Galaxy S10 phones.
42 Questions View all
Buds ran through the washer and wont charge the left side.
My buds got ran through the washer. i opened up the buds and cleaned the contacts with rubbing alcohol and blew dried it. They both work, but the left side wont charge.. everything still works on the left side but it wont charge. is there a replacement part i can buy? i thought it might of been the battery so i replaced the battery and still wont charge. Any help is appreciated. thanks!
Add a comment
1 Answer
It probably has corrosion under the charging ic. You could pull the chip off and clean it and reball it and put back on. You could also try cleaning the board in a sonic cleaner with Branson ec cleaner and dropping it in alcohol and blowing all of the moisture and alcohol off. Or you could take it to a repair shop and have them repair it. Or last option you could buy a new set of them. Unfortunately it probably will cost more to repair them than to replace them. If you have access to a sonic cleaner and the chemical to do it that's what I would try.
Add a comment
Add your answer
scott will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 21
All Time: 363
