Released September 16, 2016. Model 1660, 1778 Available as GSM or CDMA / 32, 128 or 256 GB / Rose Gold, Gold, Silver, Black, and Jet Black.
How to fix cellular update failure
iPhone 7 cannot connect to cellular. I have had it to my carrier and we determined it was a hardware issue. I replaced the left upper antenna and it worked great for the last five days and then returned to the, “Cellular Connection Failure,” fault. Is this an inherent issue with the iPhone 7 or am I doing something to foul up the antenna? Thanks for any feedback!
Score 1
1 Comment
This would make sense why it worked fine until I kept my phone in my pocket while I mowed. It probably flexed it too much
by
Add a comment
1 Answer
Chosen Solution
The iPhone 7 and 7+ are plagued with both Audio IC and baseband issues, in your case it’s baseband where the baseband CPU begins to separate from the board. The reason why replacing the antenna worked for a little bit was because you flexed the board just enough to get the CPU to make contact with the board.
This is a repair that must be handled by a specialist that does microsoldering and is not something you should DIY as it requires skill and thousands of dollars in tools to do right. iPad Rehab and STS Telecom are good choices when it comes to board repair.
Score 1
2 Comments:
Thank for the tip! iPad rehab said to try the recall route and Apple has repaired it! Thanks
by
@chadwhick7 interesting I didn't know apple issued a recall for Audio IC. I know they had one for baseband. Just beware that they just replace it with another 7, they don't actually address the issue so you may run into the same issue down the road.
by
Add a comment
Add your answer
chadwhick7 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 23
All Time: 582
