The Samsung Galaxy A40 was released in April 2019.
31 Questions View all
Samsung A40 stopped charging yesterday following him dropping it.
Hi, my brothers Samsung A40 stopped charging yesterday following him dropping it, resulting in the phone being bent. The phone is now completely dead and he has a replacement in the mail. However, he doesn’t want to lose all of his images and contacts. Any suggestions?
Thanks.
Score 3
Add a comment
Most Helpful Answer
do as in the movie. or press the phone on the back in the fingerprint area. hold and connect the charger
https://youtu.be/SS_nAF4tMFk
Score 6
3 Comments:
OMG, this worked ! Thank you Jacek Sopel.
by
'or press the phone on the back in the fingerprint area'
Genius, worked
by
It really worked my phone started charging
by
Add a comment
You have problem with:
# Charging dock (Charging port or FPC connector) - needs replacement.
# Main flex cable - needs replacement.
# FPC connector on the motherboard - needs repair from technician.
Samsung Galaxy A40 - does not charge - how to diagnose the problem
Score 1
Add a comment
He can open it up and check the connections for the battery and the charging port, a connection could have been knocked loose. He could also connect a battery to the phone and extract the data or take the battery out and charge it with a battery charger you can pick up on Amazon for 20 dollars
do you have to return the phone? If so will you get in trouble if you open the phone? You can have a repair shop take the back cover off and charge the battery and get the data.
Add a comment
Add your answer
Chloe Stephens will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 50
All Time: 3,815
