Repair and disassembly guides for Mixers.
272 Questions View all
KitchenAid speed control lever is stuck
The speed control lever on my KitchenAid Artisan is stuck. I have found some videos on replacing parts. Is it likely that some part is broken, or could it be that the problem could be solved by just opening it following the videos and trying to loosen or tighten something? Any suggestions? Thanks!
Score 1
Add a comment
1 Answer
Take a look at this Service Manual which applies to the Artisan (in addition to the models listed):
++http://www.kitchenaidparts.eu/documents/...
You will, most likely, have to open up the mixer to fix the problem. Do not remove the brushes as they can be tricky to replace in the proper position.
Add a comment
Add your answer
helmer.aslaksen will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 27
All Time: 5,704
