2nd-generation magnetic AC power adapter for MacBook products, first released in 2012. Not compatible with previous generation systems. Available in 45W, 60W, and 85W versions.
26 Questions View all
Why did my power adapter die?
I’ve got a 85W Magsafe 2 power adapter (Model A1424). The other day it just suddenly stopped charging. No LED on the tip, and no charge indicator on my MBP. I cracked it open, because I’ve got nothing to lose and $100 to potentially save.(discharged caps of course) I’m hoping for something simple like a blown fuse or something, but I didn’t see any skid marks or obvious failures on first inspection. The components are packed pretty tightly, and there’s goop all over everything so it’s difficult to troubleshoot. The cord is in good shape (from previous experience, I’m now extra careful about straining it).
Has anybody worked on these before? Is there a part that fails frequently, or is there something I should check first? Power rails etc. Thanks.
2 Comments
Are you sure you have a REAL Apple unit? Don't Replace Your MacBook Charger With a Cheap Knockoff
by
@danj Yes I am sure.
by
Add a comment
1 Answer
Most Helpful Answer
Have you tested the Magsafe on another Mac? This could be a logic board issue. The main reason magsafes fail is the lead and you can usually see it.
Score 2
2 Comments:
Boy I sure hope it isn't the Mac. Sadly I don't have another to test with.
by
I took my Mac to Apple service where they plugged it in to one of their power supplies, and it charged fine.
by
Add a comment
Add your answer
Joe will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 260
