Late-2013 MBP's "combo" headphone jack has a bias voltage for mics?
I know you can plug a TRRS combination earbud/microphone into a modern MacBook Pro’s headphone jack and have the mic show up as an “external mic” input.
You can also buy splitter cables that break out the headphone jack into two separate jacks, one for a microphone and one for headphones/speakers. So, the Mac definitely has a microphone input there.
My question is, are the microphones in these earbud+mic setups “electret” condensers that require a biasing voltage to work (my uneducated guess is yes although I’ve heard of “permanently charged” electret capsules that don’t require power).
If the answer is yes, and the Mac does indeed provide a small voltage to run the mic capsule, would that voltage be present in the mic input jack of the splitter and available to any external mic using an electret condenser element?
Also, if the answer is yes, might anyone know the voltage? I have searched far & wide on the google with no answers.
Thanks in advance!
What is your purpose here? Are you trying to setup a recording setup for podcasts or music. How many mics are you trying to setup?
by DanJ
I want to use a headset microphone with an electret condenser element that requires a minimum of 1.5 volts. Just for Zoom sessions.
by Frank Mangera
