Jura F50 water blockage
Water is not flowing through the coffee
Update (06/27/20)
Jura F50. Water is not going through the coffee. Hence no cups of fresh coffee. What could be blocking the water flow?
Open it and look for the clogging. There are different possibilities: heater calcified, brewing unit, drainage valve, the pump (can you hear it working?)
Guide
Difficulty:
Easy
5 - 10 minutes
Guide
Difficulty:
Moderate
1 hour
Guide
Difficulty:
Moderate
9 - 15 minutes
I had the same problem. It was basically the gasket in the bottom of the water tank that needed to be replaced after 12 years. I bought a new water tank for 50 EUR and it was solved.
It's much cheaper just to replace the gasket or the valve of the tank.
Past 24 Hours: 6
Past 7 Days: 15
Past 30 Days: 43
All Time: 2,030
