Device repair and information for the Soundsticks II speaker, designed by Harman Kardon in 2004.
23 Questions View all
The speaker is turned on, but no sound, how to fix it?
The speaker itself can turned on, connect to bluetooth device, and lights indicator (white and blue) are on, but it cannot generate any sound (bluetooth or 3,5 aux cable). I tried to unmute it (holding both volume button), maxed out the volume but nothing happened. What should i do to fix this?
Score 1
2 Comments:
Hi Stephanus, my Soundstick 2 is older than yours without the USB and has the SAME problem! Were u able to figure out what is the problem?
by
meus caros reparei que a entrada de som nem sempre aceita qualquer cabo, assim aconselho a procurarem um cabo novo que encaixe na perfeição.
by
Add a comment
1 Answer
How to Connect Bluetooth Speakers to Epson Projector
  • Turn the Epson Projector On by pressing the Power Button on the projector.
  • Open the menu by clicking the “Menu” button.
  • Click on the Setting and press “Enter”.
  • Open the “Bluetooth” in the settings.
  • Turn the setting “ON” for the Bluetooth audio.
  • The device which you want to connect should be in “Discoverable” mode.
  • Select “search Bluetooth device” and look for the available devices for pairing.
  • Select the required device, you want to connect.
  • Now, press “Esc” to return to the main menu.
For more detail on this post visit: https://smartelectrohub.com/speakers/how...
For more articles/blogs please visit: https://smartelectrohub.com/
Add a comment
Add your answer
stephanus ruben will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 34
All Time: 512
