The March 2015 update of Apple's 13" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
MacBook doesn't turn on. Tried every combination and to disconnect bat
I tried every keyboard combination but it didn't turned on. The fan is working but it doesn't light up the Mac logo or the keyboard. interestingly if I connect a phone it charges. I tried to disconnect the battery, the SSD and the LCD. But it didn't worked.
3 Comments
Using a flashlight shining in through the lids Apple logo are you able to see the faint image of your desktop and its icons?
Are you seeing your desktop on an external monitor?
by
Thank you for your answer. I tried as you suggested to use a flashlight but I didn't see anything. And I tried with an external monitor and I obtained the same result unfortunately
by
It didn't reboot. I pressed the wrong button sorry. Thank you for your reply
by
Add a comment
Chosen Solution
Give this a shot. Disconnect the battery and Mag-safe adopter. Press and hold the power on button for ten seconds. Reconnect the battery and then the mag-safe. This should give you a spontaneous reboot. If not go to @danj answer.
Add a comment
OK, not good ;-{
Your logic board will need repairs or you can just replace it!
Here’s the guide: MacBook Air 13" Early 2015 Logic Board Replacement
Replace a 1.6 GHz logic board (motherboard) compatible with the Early 2015 MacBook Air 13" model laptop. Fix processing issues like unexpected shutdowns, reboots or water damage. Image
Product
MacBook Air 13" (Early 2015) 1.6 GHz Logic Board
$119.99
Replace a 2.2 GHz logic board (motherboard) compatible with the MacBook Air 13" (Early 2015). Fix processing issues like unexpected shutdowns, reboots or water damage. Image
Product
MacBook Air 13" (Early 2015) 2.2 GHz Logic Board
$167.99
1 Comment:
Thank you for your answer. I don't think that my old Mac is worth the expense. I really appreciate your help and answer
by
Add a comment
Add your answer
Luca will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 102
