The Samsung Galaxy Note 5 (called the Note5) is a phablet-style phone with stylus, manufactured by Samsung, released in August 2015.
272 Questions View all
Why is my phone not going past 69% while charging?
This week I could not get my phone past 69% of charging. I saw that it said that it would be 100% charge in about 39 min but a hour past and it did not pass 69%. Should I change the battery.
Add a comment
Chosen Solution
this is another common issue. this is normal wear and tear over time, but can be exasperated by not using the proper charger and cord that comes with the phone. also, some batteries use a smart feature that learns charging behavior from the user. these are factors at play here with these types of issue.
solutions:
first you could try to re-calibrate the battery by completely draining it until it turns off (sometimes this is inhibited by a smart setting to turn off when low power is detected in settings) from there, youll want to let the phone charge to 100 percent before turning back on. see if this helps (not typical with todays li-ion batts)
if this fails, youll probably want a new battery. here is a link to replacing and to the part youll need. make sure to math the model number for correct specs:
Samsung Galaxy Note5 Battery Replacement
[[ invalid parts link ]]
if any further assistance is needed, post back here.
Score 1
2 Comments:
Thanks a lot I let the battery to drain and it worked.
by
@totemicorc ... great news. good job.
by
Add a comment
My phone has been on 69% for the past hr and I'm scared that its not gonna charge the whole night and I need my phone for school tomorrow what should I do?
1 Comment:
What happened. Did you mess up in class?
by
Add a comment
Add your answer
Eddie G will be eternally grateful.
Past 24 Hours: 6
Past 7 Days: 31
Past 30 Days: 204
All Time: 7,662
