The Samsung Gear S3 is the third-generation Samsung Gear smartwatch, first released in November of 2016. Features a round OLED display running the Tizen OS. Model number: SM-R770NZSAXAR.
68 Questions View all
How easy is it to strip out the screws; I have the right driver...
I'm trying to change out the back of my watch because the glass is cracked, but I have a feeling I may might have at least partially stripped the screws even though I have the right driver… How easy is it to strip them, and how would I go about removing them if they are?
Add a comment
1 Answer
I can tell you that very easy. It seems that they use a locking glue and sometimes they may have been over screwed making them more difficult to unscrew with the result you have seen. I striped 2 , the other 2 got out easily. So even with a good tool, it will happen. I am waiting for tools to take both out, and ordered 4 new screws. Will see if I have success. The screws are flat inside, if your special screwdriver has a point that could be a problem. Mine is flat point but even with that type two of the screws did not came out. Good luck.
1 Comment:
what tools did you use? Did you manage to remove the stripped ones? Thanks
by
Add a comment
Add your answer
KopaGeek will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 23
All Time: 433
