The Pixel 3a XL is the larger version of Google's third generation budget phones, and includes the same camera as Google's flagships. Available in Clearly White, Just Black, or Purple-ish. Released May 2019.
15 Questions View all
Is the pixel 3a volume flex ribbon cable interchangeable with the 3aXL
Hi guys I accidentally purchased the wrong part for my pixel 3aXL… I bought the pixel 3a volume flex ribbon cable instead of the 3aXL. However, the flex cables look very similar…the buttons are in the exact same placement as well as the circle cut pass-through alignment points…there is a slight difference in the cut outs on the sides… but I don't think it should affect fitment. Does anyone know if these are interchangeable?
Add a comment
Chosen Solution
I tried to assemble the pixel 3a volume flex cable and there are a few differences...
It's not quite as wide so it actually doesn't fit into the housing as well. it's incredibly difficult to get the fit for the buttons to work right. Additionally the cable is not quite as long as either, however the buttons do you line up in the right area.
The biggest problem is that the male to female connection from the ribbon cable to the motherboard does not actually lineup and is off by about 2 mm.. if I were to make it fit I would have to make a hard bend to the ribbon cable which I'm sure would damage it.
... So in a pinch I would assume that someone would be able to make it work... but I would definitely feel more comfortable just buying the be part.
Just and FYI for everyone.
Add a comment
Most Helpful Answer
Yes it’s same cable for pixel 3a and 3axl
Score 1
2 Comments:
Thank you David, you rule!
by
Unfortunately David, I tried to assemble the pixel 3a volume flex cable and there are a few differences...
Thank you tho!
by
Add a comment
Add your answer
Brandon Watkins will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 22
All Time: 166
