The ASUS ZenPad 3S 10 is a 9.7-inch tablet in the ZenPad line released by ASUS in October 2015. Model: P027.
21 Questions View all
Power button may be stuck, the tablet just continues to reboot
I dropped it and now the power button is slightly off (seems to be stuck in to the case on the bottom of it) and so it keeps coming on with ASUS and Medaitek screens but then immediately reboots. Any ideas of how to fix it?
Add a comment
1 Answer
You could open easily removing the 2 screws, remove the sd card and follow youtube instructions. When it’s open unplug the buttons connector. If the tablet stop rebooting is problem of the buttons if not I don’t know. The buttons could be easily bought on ebay. If the tablet stays switched off you could switch on with a small screwdriver touching in two pins at the back where you unplugged the buttons flex cable. You could also try how reacts when you charge and so on to discard battery, charging port…
Add a comment
Add your answer
C. M. will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 16
All Time: 278
