Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
212 Questions View all
Cannibalize internal optical drive to use as an external optical drive
I have a 20” EMC 2118 iMac that will be parted and/or recycled. I was wondering, since modern day iMacs and Macbooks do not have optical drives, if there is a kit I could purchase to convert the EMC 2118 optical drive to an external optical drive should I need one. Thank you in advance for your help.
Add a comment
1 Answer
Chosen Solution
Sadly, you have a few issues that don’t make this very practical.
This older optical drive has a PATA interface you’ll need an adaptor to convert to SATA or in a case which offers a PATA (or SATA) to USB support logic, these older cases are hard to come-by.
The next issue is the needed drivers have long since been dropped in the newer OS releases.
Score 1
Add a comment
Add your answer
Theresa Albert will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 99
