Model A1347 with 2.4 or 2.66 GHz Core 2 Duo Processor.
Check if SMC was reset
I want to do an SMC reset and did so by powering off, disconnecting cable, holding pwr button, plugging in, powering on. But is there a way to verify i reset the SMC successfully? Resetting PRAM/NVRAM is clear because you hear 2 chimes
2 Comments
I'm not sure I follow what you are looking for.
by
When you do the SMC reset, is there a way to know you did it properly? Like, sound cues, reset date/time or something like that. I want to know if i did it properly
by
Add a comment
1 Answer
Chosen Solution
A SMC reset null’s the values it holds so there is no means to tell for sure. What is the problem you think an SMC reset will alter?
Score 1
1 Comment:
It was high temps and weird fan controlling. But i think it did reset because the volume changed from max to 50%
by
Add a comment
Add your answer
Max Tech will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 22
All Time: 335
