Released in 2015, the HP EliteBook 850 G2 is an update to the 850 G1, featuring newer processors and an optional touchscreen. Repair guides and detailed information can be found here.
3 Questions View all
How can I reset BIOS password?
I have purchased a second-hand laptop and found the BIOS is password protected?
Is there a way to reset/remove BIOS password on this particular laptop?
I have tried removing CMOS battery but this has no effect (I believe BIOS password is held in NVRAM on this model).
HP say the only way to remove the BIOS password is to replace the motherboard which I am not willing to do as apart from being able to access the BIOS, the laptop is running fine.
Score 1
2 Comments
Take it back for a refund.
by
remove bios password hp elitebook 850 g2
by
Add a comment
Most Helpful Answer
You can't…
You need tools that cost more then the laptop to rewrite BIOs and then you need software versions match for firmware and INtel ME or it won's boot plus the DMI tool.
Long story short, forget about it! Return or use as is…
Score 1
Add a comment
Just read this and it gave me a glimpse of the future of bios support from computer manufacturers. Looked pretty depressing too!
HP-EliteBook-840-G2-bios-password-reset
5 Comments:
Thanks for the reply (and the link) but HP say they will only supply a SCM.bin file for machines that are still under warranty. They say the only option after this is to replace the system board which seems a bit OTT as the system does not have any other fault.
by
What is the serial number of the unit?
by
S/n: is 5CG6195QF3
by
Hmm, I tried to see if HP's website had anything to offer based on that serial number and no luck. I think you may have bought a pig in a poke. Have you any luck contacting the seller?
by
My Elitebook is still under warranty and they will not give me the scm.bin
by
Add a comment
Replace the BIOS chip, or download a dump of the BIOS chip and delete the password. I did this on a laptop HP EliteBook 820 G3.
Add a comment
Add your answer
Darrell Haslam will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 83
All Time: 10,827
