The Acer Nitro 5 AN515-53-55G9 is a laptop targeted towards budget gamers. It boasts 256 GB of storage, Nvidia GeForce Graphics and an Intel i5 quad-core processor at a more affordable price than most gaming laptops.
60 Questions View all
Nvidia Graphic card is not detected in windows 10
I can't find nvidia display adapter in device manager and i am not able to open nvidia control panel. When i try to reinstall Nvidia drivers, it says nvdia gpu not detected. Can anyone help?
Score 1
Add a comment
Chosen Solution
Hi,
Did you check in Device manager > View > Show hidden devices or in Device manager > Other Devices (if listed) just in case it is listed there for some reason?
Don't know the laptop, but check in BIOS (press F2 when Acer logo shows on startup - I think) to see if there is an option to turn on/off the Nvidia graphics adapter. If there is enable the adapter, save the changes and restart the laptop and check if it appears in Device Manager.
If there is no graphics option in BIOS, try resetting the BIOS to the default values, save the changes and then restart the laptop and check in Device Manager.
If still not there it may be a faulty GPU IC. Usually laptops don’t have a plug in GPU, it is either integrated with the CPU or where there are two GPUs in the laptop, one is in the CPU (Intel in your model) and the other is hard mounted separately on the motherboard.
Replacing a hard mounted GPU is not easy. It is easier to get a replacement motherboard
Score 2
Add a comment
Hello Well this video will help you in fixing the issue: https://www.youtube.com/watch?v=tVGbtZ8N...
Add a comment
First check your graphic card is properly connected or not. Update your bios and drivers. If your system has corrupted files, please repair. Check whether your GPU is connected correctly to your motherboard, or if it has any damage to it.
Add a comment
Add your answer
Uday will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 39
All Time: 5,104
