Released September 16, 2016. Model 1660, 1778 Available as GSM or CDMA / 32, 128 or 256 GB / Rose Gold, Gold, Silver, Black, and Jet Black.
iPhone 7 not charging
My iPhone 7 will not charge. I did a battery replacement about a week ago and tried to calibrate my phone. I was running benchmarks to drain the battery when it suddenly went from 1% to 85%. Then I continued draining the battery until it suddenly turned off. After a couple of days, I tried charging it, and here I am, with an iPhone stuck at the battery charging symbol. The iPhone works with another battery, though. What should I do?
Add a comment
Chosen Solution
I am just going to resort to getting a new battery. Thank you to everyone that tried to help.
Add a comment
Most Helpful Answer
It could be a bad tristar ic which controls charging and data transfer. You can have a repair shop test it, it only takes a minute and I doubt they will charge you.
Score 1
4 Comments:
Pretty sure it isn't, since the iPhone works just fine with other batteries. How can I rescue the battery that won't charge?
by
So any other battery will charge through the charging port in the phone?
by
@Ultra If your phone cannot charge your depleted battery it is either a faulty battery or it is what Allan said. An iPhone that cannot charge a dead battery is most likely a faulty charging component probably Tristar.
by
Yes, other batteries will charge just fine through the iPhone. I believe I discharged the battery to far. Is there a way to get it running again?
by
Add a comment
Add your answer
Ultra will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 297
