Repair information and guides for the iPhone 8 that was released on September 22, 2017. Model: A1863, A1905
What paste for cpu reballing?
Hi,
I picked up an iPhone 8 from local online marketplace. Phone turned out to have cpu connectivity issues. I decided to reball it. Already have some experience in micro soldering so managed to litf up the cpu without damaging anything. Cleaned both, board and cpu pads. And here comes the hard part for me…
I do really struggle with putting new solder balls on it… I use mechanic solder paste 63/37 and quanli a11 cpu stencil. I do preheat stencil to avoid bending. However I can't get perfect balls, some of them are bigger than other. Some are bridged… I watched few YouTube videos of people doing it and I think they use different solder paste.
Can you advice me what solder paste are you using for the job?
Cheers,
Marcin
Add a comment
1 Answer
Chosen Solution
Practice is the key. The solder paste you use depends on whether you want it to be a phone again. If it was a CPU swap for data recovery I would use low melt (138 degree) if it was going to be a phone again I would use what you are using.
The one tip I can give to you is make sure your solder paste is dry. I squeeze mine out in a tissue I do this twice or maybe three times.
Score 2
1 Comment:
Thanks for the advice!
by
Add a comment
Add your answer
Marcin will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 12
All Time: 1,418
