Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
OS can't be installed due to firmware problem
I had a problem with lower RAM socket fail.
Computer will work on 1 RAM in the upper socket.
Add a comment
1 Answer
It seems like you’re saying that the computer only has one working RAM slot because the other slot failed. It is still functional, however. And you are trying to reinstall the Macbook Pro OS, but it won’t install because of a firmware issue.
Is this correct?
Add a comment
Add your answer
Dan will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 2
All Time: 83
