Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
iMac Power Supply Test
How do I test the power supply is faulty
Score 1
Add a comment
1 Answer
Most Helpful Answer
do u have a multi meter, if yes then you can check whether you are getting proper output as specified in the power supply or not. if not then you can try borrowing a friends power supply and connect it to your device and see if your device works, if it does then your power supply will be faulty.
Score 2
Add a comment
Add your answer
Andy Crocker will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 1,138
