Repair guides and support for the fourth generation of Ford Mustang, including the Mustang GT and Mustang Cobra.
60 Questions View all
has a dead miss to it and blinkers wont work
I habe a 2004 ford mustang base body 3.8 v6 car run and everything just has a dead miss to it and blinkers wont work i replaced the coil pack what would i do next and i replaces blinker flasher fuses and the relay but blinkers come on but wont flash can some one help please
Add a comment
1 Answer
First do a compression test. If the compression is good pull the codes and find the cylinder that is missing and switch plugs and erase the code and see if the mis changed cylinders then if that doesn't work try switching the coil and erase the code if that doesn't fix it then it needs a injector.
Add a comment
Add your answer
amerrell66 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 63
