The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
How to fix WiFi cable
I have 3 WiFi cables of which 2 have bended plugs and one is decapitated. I have a broken screen assembly ready to take of its WLAN module (bar + cables) and mount it on this device but seems like that’s not possible with the retina models (as opposed to pre-retina).
Right now the options seem VERY unsettling:
  • Removing the plugs and mounting new ones
  • Stripping the wires and soldering them together with 3 good ones
What’s my easiest option?
Score 2
1 Comment
You CAN splice the wires, but shielding will be needed. If you do not have experience in this department, it would be best to replace the entire piece, or bring it somewhere that does have the experience.
by
Add a comment
1 Answer
Chosen Solution
If you still have the connector you might be able to put it back on.
If you don’t have it, then you’ll need to replace the antenna assembly, and no, you can’t splice the cable!
You’ll need to take the display assembly off, sliding the black clutch cover off to expose the antenna unit taking it off with the hinge replacing with a fresh unit MacBook Pro 13" Retina Display Early 2015 Display Assembly Replacement
Here’s the needed part 13” MacBook Pro - Right Hinge, Antenna/iSight cable You might be able to desolder the cable and slide it in.
11 Comments:
Dan the man! Are you sure about it? I can't seem to get the antenna unit off like the pre-retina models. I can unscrew it yes, but the isight cable goes through the same hinge cylinder thus locking the antenna unit + cables to it.
by
@faloude - Take a look at this MacBook Pro Retina Display Teardown to get an idea on how much work it is replacing the the antenna assembly. Pushing through the single cable is what I tend to do which is still a bit of work.
by
Holy smokes. I'm definitely not taking this route :D is there a reason I can't splice the cables?
by
Again, I often just push through the single wire through the hinge. It's not as hard as it sounds.Desoldering
As to splicing cables: Coax wire is not like other wires, it's a shielded pathway. You need to maintain the shield 360 degree's and the center wire needs an end point interface --- s --- not parallel like you do AC outlet wires ===== with a twist cap. Think of it like fiber optic cable the light needs to travel through. Then the insulation needs to have the proper dielectric impedance as well.
Understanding Coaxial Cable Terms, Specifications and Applications
by
So, can you push the iSight/FaceTime connector through the hinge then? I have a donor screen and looking to replace the WIFI and Bluetooth wiring due to broken connectors…
by
Show 6 more comments
Add a comment
Add your answer
Sam will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 53
All Time: 2,048
