Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
iPhone 4 home button replacement
I have ordered a replacement home button, not the whole home button assembly. I was wondering, before I took my phone apart will I need any glue or anything to connect it to the assembly, or if I take the old one off will it break the assembly? Thank you.
Add a comment
1 Answer
Chosen Solution
You should be able to put the plastic home button onto the actual cable as long as there is some adhesive on the plastic piece or the cable itself. You can also use double sided tape as well for a part like that.
Just a note, replacing just the plastic piece itself and the not the cable will not fix any issue related to home button performance unless the plastic button itself is physical broken or something like that.
Score 2
2 Comments:
Thank you, I am just going to place a colored home button on, no particular reason, just wanting some change in my phone.
by
Then you should be just fine. Just use caution when removing the cable from your original button. A little heat from a hair dryer should help if it's stubborn.
by
Add a comment
Add your answer
Josh will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 1,104
