Eighth generation of the Honda Civic.
59 Questions View all
Where is Bluetooth module located in Honda Civic 2010?
I have a Honda Civic 2010 EX-L with Navigation and Bluetooth. I’m replacing the factory radio with an aftermarket stereo and need to locate the Bluetooth (aka Honda Handsfree Link or HFL) module to make wire connections. I already looked under the dash and steering wheel but no luck. Thank you in advance for your help!
Add a comment
1 Answer
Chosen Solution
I would imagine it’s part of the factory head unit
Score 2
3 Comments:
My understanding is that it looks like this: https://i.ebayimg.com/images/g/DRIAAOSwT.... I need to T-tap into one of the wires on the green connector that plugs into the module, to keep my handsfree calling feature control on my steering wheel. Thanks.
by
@gosaigo
@hootonberg may be correct.
It's not shown anywhere in the service manual not in the component location section or even in the wiring diagrams or not that I could find anyway.
by
@jayeff Thank you for taking the time to check the service manual. It’s probably part of the head unit that I replaced, as @hootonberg said. When I contacted iDatalink Maestro, they led me to believe that it’s a separate module located somewhere under the dash on the driver’s side. I could not find it after taking off all the covers On the driver’s side. I decided to skip the steering wheel controls on Bluetooth. Thank you both!
by
Add a comment
Add your answer
Sai will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 17
All Time: 1,039
