Repair and disassembly information for Samsung's flagship S20 Android smartphone, released in March of 2020.
50 Questions View all
Moisture detected in charger port.
I have moisture detected in my charging port notification. I cannot charge my phone via my USB-C nor can I use my cars Andriod Auto feature for navigation as a result.
I cleaned the port with 90% Isopropyl alcohol and a tooth flosser thingy (powered off obviously). I dried it out and the notification went away. However it has reappeared a week later when I plugged in another cable.
-I’ve tried different cables various brands and originals with no luck.
-I’ve tried clearing the USB cache.
-I’ve tried a factory reset.
Add a comment
Most Helpful Answer
Replace the charging port or the whole daughter board if that dosent work then clean the battery connector and the battery connector socket, if that dosent work replace the battery connector socket.
Score 1
Add a comment
I had that same problem and solved it changing daughterboard as suggested by Em4n
Add a comment
Add your answer
Combatical Radical will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 7
All Time: 1,691
