The Samsung Galaxy J2 is an Android smartphone that was released in November of 2016.
Black screen after dropping
Hi there! I dropped my phone this morning and now it has a black screen. When I power the phone on it it vibrates. When it’s fully powered I can here messages, notification, etc. The touchscreen does not work as I tested it by installing vyser(an app used to control phone from pc and this app displays phone screen). Also when powering on phone or turn phone on after boot, I see lines displaying for a second or 2.
I tried:
  1. Taking the battery out and holding the power button for 120secs.
  2. I tried booting to recovery.
I am aware similar questions have been asked, but none helped or fit the issue.
Thanks. b
Score 1
Add a comment
1 Answer
Chosen Solution
Hi,
The LCD screen may have been damaged by the fall. They cannot be repaired, they have to be replaced. As a DIY repair all you can do is open the phone and check that the display flex cable is still connected properly and if so temporarily replace the LCD screen and check if it works OK to check if the problem was the LCD display or perhaps on the systemboard.
Here’s video that shows how to replace the screen in your phone.
Replacement screens are available online. Just search for Samsung Galaxy J2 LCD screen to get results for suppliers.
Score 2
3 Comments:
Hi. Thanks for answering. I forgot to mention that the phone has 0 cracks after and before drop. Does this change your answer. Though there is a few scratches, but they're not noticable.
by
@Meezaan Ryklief
There are very delicate connections inside a LCD screen which may have been broken by the dropping of the phone. This may not be noticeable on the outside except that the screen no longer works.
The only way to know whether it is the screen or not is to replace it and check.
by
Ok thanks, for replying
by
Add a comment
Add your answer
Meezaan Ryklief will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 2,393
