Noise cancelling headphones, line in.
3 Questions View all
My battery does not seem to be making contact inside the headphones
I purchased these about a year ago, so the warranty is out. Already checked for normal things like wires disconnected, and corrosion. I did a thorough cleaning with vinager and still nothing. Then I noticed when I put the battery in, and pushed down hard on the top, the green light came on. This worked a few times, and am wondering why it is doing that. Recently I had them sitting on a table, no drops or falls to cause something to be dislodged…
Add a comment
1 Answer
Most Helpful Answer
I had the issue with a pair in which the battery had been left during storage. As often happens with those copper-colored batteries, it leaked. I was able to apply a few drops of white vinegar to the spring and spring holder in the little door to the compartment, then rinse and repeat without getting liquid inside the headphones. I also used an emery board to brighten the part of the spring that contacts the battery. Again, don't get dust inside. Even though you cleaned it, there could be a little bit of corrosion where the spring is held in place or where the electricity flows into the headset, or on the tip of the spring. I put in a new battery and they worked!
Score 1
Add a comment
Add your answer
image blue will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 25
All Time: 294
