24" display; Built-in iSight Camera, Microphone, and Speakers; 1920x1200 resolution. Released October 2008, identified by model number A1267.
85 Questions View all
No image showing up, but everything else works, what problem it is?
My 24” Cinema Display stopped displaying anything (totally darkness) recently, but everything else seems works fine, such as speakers, iSight cam, and my MacBook can still detect it. I thought it might be the all-in-one cable issue, so, I bought one used over eBay and have it replaced, but it is the same issue, black screen. I also tried using a flash light on the screen, but can’t see any images at all. So, at this stage, what’s the most possible cause? Any thoughts?
Thanks,
1 Comment
@lovecd could be the LCD but I would suggest you go ahead and post some pictures of all of your parts in particular the logic board. Let's see if there are other things that cause this.
by
Add a comment
Chosen Solution
@lovecd could be the LCD but I would suggest you go ahead and post some pictures of all of your parts in particular the logic board. Let's see if there are other things that cause this. You should at least have a backlight even if your panel is not working.
Check the voltage on your logicboard. Between TP81 and chassis ground you should have between 23.3 and 25.7 Volt. If you don’t it is most likely the logic board not the panel.
Score 2
7 Comments:
Thanks, will try that. A question though, if the issue is with the logic board, why I can get all other functionalities, such as iSight, speakers, USB ports working?
by
@lovecd different circuits on the logic board. They are probably separated since you wont need the video or backlight circuitry for that etc.
by
Here is the update. I checked the voltage between TP81 and chassis ground, it showed some numbers, but then changed to 1 quickly. Does this mean the logic board might be the cause?
by
Yes it is possible. You need that voltage. What are the numbers on the logic board. Maybe we have luck with finding the schematic
by
What do you mean the numbers on the logic board?
by
Show 2 more comments
Add a comment
The… screen? Considering you already replaced the cable and your Mac still detects it, the only assumption really left would be that the screen itself is just dead (not the whole monitor)
1 Comment:
I see, thanks.
by
Add a comment
Add your answer
Tom will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 163
