First-generation Apple iPad with Wi-Fi, available with 16, 32, or 64 GB. Model Number A1219. Repairs are straightforward and do not require heat.
130 Questions View all
Touch not responsive after install
Two lcd/digitizer assemblys have ended up with this problem. After a few weeks after a successful install, the iPad suddenly becomes nonresponsive to touch but works otherwise. Any advice??
Add a comment
1 Answer
Did you ever get this fixed? I had a similar issue at my shop in which digis were going dead for seemingly no reason, it turned out that the frame of the iPad was bent just enough to hurt the digi after a couple weeks of use. Left us with a reasonably unhappy customer, but after correcting the bend we haven’t seen them since. Definitely check the frame for bends and try correcting that.
Add a comment
Add your answer
Michelle Stephens will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 37
