Guides and support for various television (TV) brands and styles.
Led strip replacement question
LG TV - 55LF6000UB Have blinking LED’s so was in process of replacing the LED strips but discovered a 4 inch burn hole in the reflector sheet and also the plastic light filter has some burn damage. Is this still just a LED strip problem? Can I continue and replace the strips or is this now a fire hazard. Thank you.
Score 1
2 Comments
Hi @beiss5
Possible to share some pics and let us have a look?
Adding images to a new question
by
Pictures added. Thanks for your help.
by
Add a comment
Chosen Solution
@beiss5 the burning is over and done with. That happened due to some critical failure with the old LEDs. You can continue with replacing the strips. Only issue is that you will have a darker spot on your screen due to the burned diffuser sheet. At least clean some of the soot off and see what happens.
Score 1
Add a comment
Try replacing the LED strip, it might work. As a last resort, give it to professionals for repair.
Add a comment
Add your answer
Dennis Beisswanger will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 6
All Time: 406
