Where is the oil drain
Where is the oil drain on my Briggs & Stratton motor 158cc 5.50
Some engines will have an oil drain plug located on the bottom that looks like this:
But, some oil drain plugs will be covered by the housing, in which case, even the manufacturer says you can tip the engine over and drain it out of the fill tube.
Seize tool for oil drain plug
@azharmdidris make and model for your engine?
Past 24 Hours: 3
Past 7 Days: 7
Past 30 Days: 56
All Time: 537
Edward Bois we will need an engine number or model number for this.
by oldturkey03
