Repair and additional information for the LG LMXS27766* refrigerator—a bottom-mounted freezer model with French door access, automatic ice maker, and built-in compact design. This page covers information for model numbers matching the pattern LMXS27766*.
1 Questions View all
both the refrigerator and freezer not cooling properly.
Hi Lady Tech, any help would be greatly appreciated. I have a LMXS30776S/00 with both the refrigerator and freezer not cooling properly. Performed the voltage test on CON201 (1&4 pin) after pressing the test switch. Voltage got up to ~50V Max. Left connector off and noticed LED blinking three times. Main Control Board? Thanks Brian
Add a comment
1 Answer
Chosen Solution
Brian Greeson- I apologize for taking so long to reply. You should have 180v - 230v at con201 withinin 30 sec of plugging unit in. Since your only getting 50v that tells us the main board isn’t providing the proper voltage t the compressor. You need the main control board.
Score 1
Add a comment
Add your answer
Brian Greeson will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 68
