Released November 4, 2017. Model A1865, A1901. Available as GSM or CDMA / 64 or 256 GB / Silver or Space Gray. (Pronounced the same as "iPhone 10.")
Why does my iPhone keep randomly switching off?
I have this problem with my iPhone X where throughout the day, even at say 53% battery left, it randomly switches itself off. I wouldn’t mind so much if I could just switch it back on but the issue is that I can’t switch it back on by it’s own power, it has to be plugged into a power source, whether it be a PC or by a plug socket. Any ideas what might be causing this issue? I had thought of possible a faulty battery connector but if I switch it off normally and then switch it on normally it’s fine. Thanks.
Add a comment
1 Answer
I would take a look at the maximum capacity in the battery health tab. Typically when it gets below 85% is when I recommend a replacement as that’s roughly when people notice battery trouble. But it could be an issue with the port as well. The iPhone X and above are picky when it comes to charging ports. If it’s not connected, functioning properly, or it was replaced with an aftermarket port, it can cause issues like this.
Add a comment
Add your answer
Brandon Frost will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 80
