SD Memory Card maximum
What is the maximum size SD memory card the Canon PowerShot A580 IS will accept?
According to the User Manual your camera accepts SD memory card/SDHC memory card/MMC Card/MMCplus card/HC MMC plus card. This means you could probably use a 32GB card. I do believe that most people do not go higher than 8GB to prevent read/write errors and buffer overflow etc.
My 590 is keeps saying memory card error and won't do anythinng what is the problem?
Hi brianshackelford607,
Have you tried a different SD Card?
Try using a card reader connected to a PC to verify if your SD Card is still OK or if there is a problem with the camera
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 5
All Time: 4,394
