1.83, 2, or 2.16 GHz Core Duo processor
281 Questions View all
What is corrupting my display?
I am getting parallel, diagonal lines from top left to bottom right all the way across the screen on my 15” MabBook Pro A1150. They are made up of alternate groups of 4 small squares of red/blue and then blue on white.
I can still the display behind theses lines and the cursor is no longer an arrow but a white oblong with black lines on it. I’ve tried to mirror the display on my 13” MacBook but neither will see the other.
Has anybody experienced the same and can you tell me where to start looking?
Add a comment
1 Answer
Most Helpful Answer
What do you see when you connect your system to an external display?
Your system has an older video standard DVI.
You likely will need an adapter like this one: StarTech.com DVI to VGA Cable Adapter - Male DVI to Female VGA so you can plug in your VGA monitor. If you have something else you’ll need a different adapter/
Score 1
2 Comments:
Hi Dan, thanks for the quick response. I did know that I had to get an external monitor to check, but at the time I had neither monitor nor cable to connect to my tv. I was hoping that someone had seen this sort of thing before. I now have a cable and I see the same on the tv as I see on the laptop so I know it is the graphics chip which I believe is part of the motherboard, is that not so?
by
Sadly yes ;-{
Your GPU has failed, time to get a replacement system.
by
Add a comment
Add your answer
Peter Benson will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 15
All Time: 74
