The Dell XPS 15 9500 is a laptop released by Dell in May 2020. It can be identified by model number XPS9500.
6 Questions View all
Replacing Qualcomm AX500 Killer Wifi
This Qualcomm AX500 Wifi does not work for me using Linux and I wanted to replace it with a Intel Wireless-AC 9260 (M.2 (PCIe)). However on the top left corner there is the card reader (green) where the Wifi module used to be.
Any change replacing the Wifi (red)? Is is soldered to the board or still an M.2 PCI card?
Score 1
3 Comments
@haa29 I am old so I confuse easy? You want to change the WiFi module on what device? What are you comparing this to? However on the top left corner there is the card reader (red) where the Wifi module used to be.
Any change replacing the Wifi (green)? Is is soldered to the board or still an M.2 PCI card?
by
Apparently this thread is for a Dell XPS 15 9500. And when you do an Internet search for replacing the Wifi module on a Dell XPS 15 it will be located in top left. How you expect to answer this questing if you do not know all this? (Wifi is red and card reader green)
by
@haa29 no reason to become testy or wondering how I was going to answer. Obviously you are the one that has the motherboard and laptop right there so all you needed was to clarify what is on your board to see if you can change the WiFi board.
by
Add a comment
Most Helpful Answer
Hi @haa29
It might depend on which model XPS -15 you looked at when you say that the WLAN card was there before. Because the service manual shows that it is located where you have indicated and that the I/O board is in the top left corner. It’s always better to go with the service manual (or a teardown video) for the specific model variant, just to be sure unless the service manual is for the model series i.e. XPS 15. and it covers all the variants as sometimes happens.
Have you removed the cover exposing the WLAN card antenna cables’ connections to see if the WLAN card can be removed, you didn’t say? Your image shows the WLAN card with the antenna connections being covered.
In the systemboard replacement procedure on p.39 of the service manual the image shows the WLAN antenna connections on the card without the cover, but it is a bit hard to tell whether the card is hard mounted or not. The manual doesn’t say how to remove the card so the inference is that it is hard mounted as usually they do say if it can be removed, but maybe not. You can only check.
How do you propose to route the antenna cables to a WLAN card installed in the M.2 slot without possibly increasing the interference to the received signal from the systemboard? Antenna cables are carefully routed in a laptop to minimize any possible interference. Also would they be even long enough to reach?
Score 2
Add a comment
Hi Andreas,
I have the same problem. Although I have the wireless adapter somewhat working after building the 5.10.1 kernel and installing firmware, wifi gets lost after suspend and a reboot seems to be needed.
I read the service manual, which shows how to completely dismantle the latop, but dos not say anything about removing the wifi card separately. Its quite frustrating, but I become more and more convinced that its soldered to the system board.
Have you learned anything in the meantime ?
Cheers
Rob
Score 1
1 Comment:
Hi, Rob
I have the same problem...while the card is soldered for sure...Have you found the solution yet..?
Can you please put the link here for the m.2 adapter you are using so i can buy that too..
Thanks in advance...
by
Add a comment
I also have XPS15 9500. It includes two editions, one is AX500 (Qualcomm) another is AX1650 (Intel native). Both are not module cards. It is solder on the main-board, you cannot detach it.
https://www.dell.com/support/manuals/en-...
Add a comment
I believe the wifi module is a soldered down part in "M.2 LGA Type 1216" form-factor.
It's probably possible to replace it with any compatible m.2 1216 modules from other vendors (e.g. Intel part number AX200D2WL wifi6 or AX210D2W wifi 6e - both have good Linux support), but since it's a soldered-down part replacement is not for the inexperienced or faint of heart.
The other solution is to try and use an m.2 "m key" to m.2 a/e key adapter in a spare SSD slot, and try and get the wifi antenna cables to reach (by either extending the antenna cables or using an m.2 slot extension), and also the case to close. m.2 m key doesn't have USB, so you probably won't get bluetooth that way.
No easy answers unfortunately.
Add a comment
Add your answer
Andreas will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 78
All Time: 5,580
