With the exception of the game console itself, video game accessories can be anything from the controllers, memory, power adapter (AC), audio/visual cables, and more.
130 Questions View all
Xbox one Elite 2 controller missing components near right joystick
Hello,
I’ve got a problem with an Xbox Elite 2 Controller. I replaced the right joystick and it works fine except that it does not register a button press of the right joystick.
In the process I may have knocked off two components right next to it:
Any help with identifying the missing components and what to replace them with is much appreciated.
Update:
I really want to know, so I got my hands on another one of these that needs fixing for a good price. This is what the components look like:
Add a comment
Most Helpful Answer
If anyone cares, I managed to fix it. The lower component is a 32 ohm resistor. I just searched old junk PCBs and took one that fits. The upper component is a diode and this one is not critical.
Also there was a broken trace, so I soldered a jumper wire from the button switch to the 32 ohm resistor and everything was working ok then. I skipped replacing the diode because it’s too much trouble in that awkward spot with the broken trace. No clue what the diode is there for.
Desoldering that joystick module was a PITA because the PCB somehow eats up a lot of heat. Much more annoying to work on than the previous controllers! Now all is good :-)
Score 2
Add a comment
Probably the same as the capacitor next to it. usually when a component forks off in two directions like that the caps are identical.
2 Comments:
Hi there, thanks! I uploaded another picture with the two components on the board. The component looks different than the cap. Could it be a resistor? The one above it is a small black box, a bit taller than the cap. It's connected by two traces. Could it be a diode maybe?
by
i cant really tell what it is in the second photo, to blurry. It kinda looks like a switch,
by
Add a comment
Hey Chris,
Thank you for posting this! Because of you I was able to fix a elite 2 controller I bought for a good price to fix. I had given up because there were some components missing but because you found out it wasn't a necessary component I just put in New sticks and tried it and voila it works again. Now I need a new battery because the one that is in there is swollen. Anyways thanks for all your hard work it has really helped me with my controller :)
Add a comment
Add your answer
Chris will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 347
