Larger version of the Nintendo DSi, released March 2010 in North America. Most repairs are accomplished with only a screwdriver and prying tools.
157 Questions View all
broke off the connector for power supply
I recently got a used DSi XL untested. When I plugged it in, the yellow charging light blinked, and it did not power on (occasionally an attempt to power it on would result in the blue light turning on for a split second, but most attempts to turn it on resulted in nothing). I cleaned the battery compartment with 91% isopropyl alcohol. I tested the battery and it seemed to be working. After reseating the battery in the cleaned compartment, I still had the same problem… so I unscrewed the back and took it off (careful not to tear any of the ribbon cables). If anyone knows a fix to this issue, thats also welcome, but as of right now nothing is going to work because I also broke the connection of the power supply (which is my main question):
unfortunately when I was removing the circuit board under the battery compartment, I misunderstood the instructions and removed the entire white square with the + and - (red/black) wires (as opposed to removing the piece within the white square). I was wondering if I should solder it back on (and if so, what tools are needed for smthn so small) or if there are other possible solutions to reconnect the supply current (like maybe just securing the piece exactly so with electrical tape? would that be enough to complete the connection?).
TL;DR
I broke off the piece that connects the battery to the motherboard and dont know how to reattach it/if reattachment is possible.
thabks in advance to any answers!
Add a comment
Chosen Solution
Looks like you’re very lucky and none of the solder pads have been badly damaged/ripped away from the PCB.
This should be a simple job of using a fine tipped soldering iron on a medium/low heat with a dab of flux to re-attach to the board.
If you are not comfortable soldering I wouldn’t attempt it yourself as you may further damage the component or board.
Score 2
4 Comments:
Link is right. The only possible way is to solder it back on the motherboard. And I agree, you're lucky that the solder pads are not ripped away from the motherboard. This could've happened easily.
by
@aylomenz thanks so much! I have no experience with soldering so I will look for someone who can help me. I know a few people who might have the skillset!
@dan0 I'm glad it wasnt worse, Im grateful for my luck! I permanently broke the last ds I tinkered on so I was really worried it was done for.
by
Happy that it's not the case now that's is broken down for good. Still fixable, but yeah you need a soldering iron :).
by
I also had this problem, but instead of ripping off the white piece intentionally I did it accidentally because the powerboard connector was stuck in the port and I used too much force trying to get it out. Are there any places to buy a replacement for this piece?
by
Add a comment
Is thermal paste a good alternative?
Add a comment
Add your answer
sharkyboy will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 55
All Time: 1,345
