A mid-range smartphone from Samsung released in 2019.
125 Questions View all
Will device boot with no battery?
Hey, i was taking a look at a phone for someone who said it wont charge or turn on.
When plugged in a lighting bolt in a circle appears but no battery percentage. i took apart the phone and disconnected the battery then plugged in the charger and same thing
Lighting bolt in a circle with no battery percentage
Does this mean the battery is the problem? The device in theory should boot without one while plugged in like a laptop.
Would this mean the issue is software and not hardware since the charging port is working.
Score 1
Add a comment
Most Helpful Answer
Austin Sidman this “ i took apart the phone and disconnected the battery then plugged in the charger and same thing. Lighting bolt in a circle with no battery percentage” makes the battery the prime suspect. Replace the battery then re-evaluate. There are multiple other board level hardware issues that could cause this but start in an orderly fashion so as to not try to change/repair parts that don’t need to be replaced/fixed.
Samsung Galaxy A50 Battery Replacement
Score 1
Add a comment
It could be software related, but to me it rather sounds like a problem with the part of the circuit that charges the phone (or the battery itself).
It is with some phones possible to boot without a battery depending on the amount of power the phone consumes, and the chargers ability to provide this power.
Add a comment
it can work with some devices or with some ways for example with USB, sun energy, or you can use it when you power off it
Add a comment
Add your answer
Austin Sidman will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 38
All Time: 1,549
