low-cost notebook with at least basic gaming power, includes the models G50-30, G50-45, G50-70, G50-80.
38 Questions View all
Can I upgrade my laptop with 8 GB Ram and 250 GB SSD or 500gb SSD
I have a intel i 3 Lenevo G 50-70 Laptop with 4 GB Ram and 1tb Harddisk with 2 GB internal graphics , Can I upgrade my laptop with 8 GB Ram and 250 GB SSD or 500gb SSD along with the hard drive available as 1tb. & Also can use m.2 SSD in my laptop.
Add a comment
1 Answer
Most Helpful Answer
Hi,
The short answer is yes to the ram and SSD but no to the M.2 SSD
You can install up to 16GB (2 x 8GB) of DDR3L 1600 PC3-12800 SODIMM ram.
You can install a 2.5” sata SSD in a caddy (supplier example only) to increase the storage, but you will have to lose the ODD (optical disc drive) to do this. Also if you install a sata 3 SSD it will only operate at sata 1 speeds because this is the speed of the ODD sata port. The HDD port is sata 3
Here’s the hardware maintenance manual for the laptop.
Go to p.36 to view the necessary pre-requisite steps and then the procedure to remove the optical drive.
Go to p.41 to view the necessary pre-requisite steps and then the procedure to remove/replace the memory
Here’ s a link to a supplier of ram and SSD compatible with the laptop. It is only shown to give an idea of the cost and what options there are.
There is no M.2 slot in the laptop.
Score 1
Add a comment
Add your answer
vishal patwaria will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 17
All Time: 89
