This guide is for the Lenovo Yoga 720-15IKB. Released in 2017, the Lenovo Yoga 720-15IKB is a 2-in-1 laptop with four distinctive orientations to use it in.
7 Questions View all
Lenovo Yoga 720 15ikb: SSD JIS #1 screw replacement
I own a Lenovo Yoga 720 15ikb that's SSD has a JIS #1 screw. I may have stripped it with a Phillips head screwdriver. I am working getting the correct screwdriver for it. If it is too stripped is there anywhere or anyhow I can replace the screw even if it's not a JIS?
Add a comment
1 Answer
Chosen Solution
Yes, of course, get the correct screw driver.
Steady your work and exert firm but cautious pressure sensing when the srcew driver is engaging the screw.
When putting it back in just tighten firmly but NOT too tight! Many people exert too much force.
Score 1
1 Comment:
Yes, I got this a bit late and apparently I am one of those that pushes too hard. I read this, attempted to loosen it and that's when I stripped it. For now, I don't see myself needing to remove it any time soon, so I suppose I'll need to cross that bridge when I come to it. Thank you for your answer.
I also came across another post in another repair guide that said a good replacement for this computer would probably be a Phillips M2x3mm give or take .5mm.
by
Add a comment
Add your answer
Andria Olivier will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 3
All Time: 268
