Released in 2015, the Lenovo Yoga Tab 3 8 (model number: YT3-850F) was only available in slate black with 16GB memory.
14 Questions View all
My screen is flickering in grey, black white patterns what to do?
For a little while my screen has started flickering in bands of white/black/grey for a few seconds, after which it rights itself? Is it a sign the display is near its end? What shall I do? Thank you for your help.
Add a comment
1 Answer
Chosen Solution
Hi,
As a DIY repair all you can do is to open the tablet and check if the LCD display flex cable connection is secure to the systemboard and if so, then to temporarily replace the display module and check if it now works OK.
Here’s the ifixit Lenovo Yoga Tab 3 8 LCD Replacement guide which will help to do this.
Here is a link that will get you the correct replacement part for your particular model variant. Type YT3 850F (if this is part of your model number) in the search box and then select which model variant is yours i.e. ZA09, ZA0A or ZA0B.
Then click on Select Commodity > Covers all second LCD & LED Displays to find the part number for the display assembly. Then search online using the part number only to get suppliers that suit you. The part number is usually also printed on the back of the LCD display somewhere if you wish to verify that you have the correct one.
It appears that the same displays are used in all 3 variants, except the -0A version which has only the one option (part #5D68C02838), whereas the others have two to choose from, (part #5D68C02838 & #5D68C07614)
Score 3
1 Comment:
Thank you very much! Your explanations were very clear and the guide easy to follow. This fixed my problem.
by
Add a comment
Add your answer
Eva Liedermann will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 646
