Released in June 2020. 10th generation intel device. Available in slate gray and orchid. Model identifier 82AS.
3 Questions View all
What is the repairability of Yoga Duet versus Surface Pro 7?
I’ve known so far that repairability of surface devices are bad with exception of Surface Pro X.
Therefore, it would be amazing if someone can say at least if it’s easier to access Yoga Duet 7 than Surface Pro 7.
This should be a selling point if it’s easy to repair.
Add a comment
1 Answer
Chosen Solution
Hi,
Don’t know about either of the laptops, but here’s the hardware maintenance manual for the Lenovo Duet 7 13IML05 taken from this webpage which at least documents how to remove all the components etc which at least makes things a bit easier.
Also the parts link on the support webpage also gives you all the part numbers for the various components so that you can find them easier online by simply searching for the part numbers.
Score 2
Add a comment
Add your answer
integratemiguelsantos will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 8
All Time: 542
