The March 2015 update of Apple's 11" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
142 Questions View all
2015 MacBook air fan runs, high cpu usage at idle, not overheating.
Ive already
Reset SMC
Reset NVRAM and PRAM
Ran Hardware/ mac diagnostic tool on boot up.
The computer is running slow right at boot up. I have not recently installed anything or changed anything. Issue started after it ran out of battery last night. Activity monitor shows that it takes 22 to 70% of cpu when open. Running at ~80% idle cpu usage. GPU usage is minimal. Issue persists in safe mode, which I had a spike of 93% cpu usage with nothing running. Even with high CPU load, the mac is not heating up like it normally does.
The mac community pages have been very unhelpful. I factory reset it no more than 2 months ago, and would like to avoid doing that again if at all possible.
Score 1
2 Comments:
Hi,
maybe try to change the thermal paste ? maybe it’s overheated on the inside and the fan tries hard to compensate the heat that can’t be dissipated.
Hope I helped. ;)
by
Pretty sure after some troubleshooting, that the issue is a bad heat sensor. Im waiting on a P5 driver before I can actually get in and check it out. Will update then.
by
Add a comment
1 Answer
try adding new thermal paste the fans could also be clogged or one could be damaged try cleaning the fans
Add a comment
Add your answer
Jacob will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 690
