2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
535 Questions View all
Screen wont turn on after battery replacement
I have a Macbook Pro Retina Mid 2012 and I replaced the battery. After putting everything back together and verifying all items were plugged back in I charged the laptop backup. Upon pressing the power button, I get no chimes, and no screen. Its just black. The fans do start when the power button is pressed, the Caps Lock does work on the laptop as well. I dont have an external screen to test with so that makes it hard. I have tried a few resets including a SMC reset. Nothing seems to work.
1 Comment:
Did you get the correct display? The Mid 2012/Early 2013 use a different part (different pinouts)
by
Add a comment
1 Answer
You dont have any TV screen nearby to check if the graphics unit work?
Maybe you damaged some cables trough your replacement?
Add a comment
Add your answer
Nathan Caudill will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 101
