4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
970 Questions View all
weird problem with iPhone se
i have a 1st gen iphone se that for the most part works but it won’t turn off because the power button doesn’t work so i use the feature in settings to try and do it and instead of turning off it restarts and goes into a boot loop until i plug it in and then it boots up fully. it also turns off by itself randomly as if the battery has gone flat. could this be a bad battery or something else
2 Comments:
Did you replace the battery?
by
it randomly fixed itself
by
Add a comment
1 Answer
i figured it out, it's the power button flex cable
Add a comment
Add your answer
Cheap gamer will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 72
