I am Unable to See 144hz Refresh Rate On My New Monitor Settings?
I recently purchased the Asus VG248QE monitor which has 144hz refresh rate screen. My problem is, I am only getting 60hz maximum from it.
I tried to connect my monitor from different HDMI cables and from different ports but the results are the same.
Why am I not getting the highest 144hz refresh rate options?
1 Comment:
@shreyamathur651 - Are you connecting it to the 20" G5 iMac you picked here?
If not, what is the system you are connecting it too.
by
Add a comment
Pretty sure you have to use the display port instead of the HDMI port
1 Comment:
The G5 has a Mini-VGA port
by
Add a comment
Go to your desktop. Right click and select screen resolution. Choose advanced settings and here choose 144hz refresh rate. If you aren’t seeing 144hz option then might be a problem in connections, Drivers. I found one reference article for you. You need to troubleshoot your settings and all to figure out things.
Add a comment
Add your answer
Shreya Mathur will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 298
